7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,072 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44985 12/13/2002 9:20 PM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | Just bought this truck, sorry if I sound stupid, but I have the frame in the garage and want to upgrade the driveline for highway speeds. I gather that I need a T-5, are they all the same? What do I need to bolt this up to the existing bellhousing? Can I use a solid driveshaft? Would I still need to change ring & pinion? Mine is column shift- is that a problem? I really appreciate any help, I'm new to this! | | |
#44986 12/14/2002 4:48 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Changing the ring/pinion, with one of the units from Patricks would help. I think it changes your 4:11 to a 3:55. That will drop your engine rpm down at highway speeds.  | | |
