4 members (Hotrod Lincoln, Ranger, Peggy M, carbking), 44 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#449754 09/06/2008 11:57 PM
hey guys im having a little bit of a problem here. the truck still idles fine but as i acclerate, it seems to only accelerate in increments like its short on fuel for a second and then it gets it and then repeats that process. eventually it levels out and is ok once it gets up around 2,000-2,500 rpm but its just strange. ive asked around and msot people seem to think it has to do with fuel delivery and more specifically a fuel pump on its way out or possibly a clogged fuel filter. any suggestions on where to start?
H Online: Content
Start with a fuel pump volume test. Disconnect the fuel line at the carburetor, slip a piece of rubber hose on, and put the hose into a container. Start the engine and let it idle. There should be enough fuel in the float bowl to idle for some time. The pump should deliver at least a pint in 30 seconds, if it's in good shape and the inlet line isn't restricted.
If the volume is low, connect a pressure/vacuum gauge to the outlet. It should produce about 4 lbs. of pressure, and hold it for a few seconds after the engine is shut off. Then check the inlet. There should be about 10-15 inches of vacuum, and that should stay put for a short time after stopping the engine. Low vacuum or pressure, or an immediate drop to zero is cause to replace the pump. Good results on pressure/vacuum tests but low volume- - - -look for restrictions in the tank-to-pump line, or a blockage inside the tank. Also check any filters or strainers for restrictions.
H Online: Content
I've seen this symptom repeatedly on engines with carburetors and mechanical fuel pumps- - - - -surging on acceleration due to low fuel pump output or a clogged fuel filter, and just barely able to maintain steady RPM on a light-throttle cruise. A slight increase in fuel demand drops the float level, and a lean surge develops. The float bowl doesn't have to get empty, just a drop from the normal level of the fuel in the bowl in relationship to the venturi makes the mixture go lean.
well actually, i didnt want to say anything at first cause i got chewed out for it last time but this is on a 95 suburban with a fuel injected 350. i just really needed advice and figured this was the best place to get it. any changes in advice because of the fuel injection?
H Online: Content
Send me an IM, and we can talk about troubleshooting techniques off the main board. There is an entirely different diagnosis process on a computerized fuel injected engine. What you're describing does not sound like fuel problems on that one.
