2 members (VicZ, klhansen),
118
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44963 05/19/2005 4:25 AM | Joined: Apr 2005 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 52 | I bought an auto trans crossmember out of a 67 to use in my 66 C-10 V8 that was a manual truck. I was told that the early 60's through 72' would fit...I cant seem to get it in there. My original manual crossmember had the center torched out so removal wsa easy but no matter what angle I take at it the new one wont go in. Do I need to cut the rivets out of the auto crossmember so it is in 3 pieces then bolt it together?? Help!!
Thanks | | |
#44964 05/19/2005 3:21 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Yes, use 3/8 bolts to go back together. Put the two upper braces in after the crossmember is in. Brian | | |
