8 members (FAST55, cmayna, Cletus1950, Phak1, Peggy M, Flatblu4748, Charles in CA, Gray_Ghost),
65
Mod | | | Forums66 Topics128,128 Posts1,056,686 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44959 07/18/2002 3:47 AM | Joined: Nov 2001 Posts: 38 Member | | Member Joined: Nov 2001 Posts: 38 | Hi folks,
Here is a little up-date on my drive line noise. I pulled the transmission last week and even though the bearings and shafts looked very good I ordered all new bearings for it just in case. I start looking at the drive shafts and the rear drive shaft moves in and out of the tube a good inch or more. I remove the nose piece on the diff and ball bearings start raining out the bottom. I remove the rear cover and there is a ton of junk in the bottom, mangled bearing cages, ground up races and big and small ball bearings. Both the front and rear pinion bearings were totally gone only the inner race was left on the rear and the front had a partial outer that cracked when I pulled it out. I am truly amazed that the rear end worked at all and I have driven it a few hundred miles. I was telling you all that the truck felt like a cluster bearing was bad due to a binding when going from forward to reverse I think this is it! I have new pinion bearings on order and I cleaned out the front case this afternoon, no other broken pieces and the gears while marked and worn are all still good. At this point I will have a new drive line from the clutch back, all the bearings from the input shaft on the transmission to the rear pinion bearing including all the ball bearings in the drive shaft!
Now here’s the question of the hour, actually two. First the nose piece on the diff is worn with a groove about 1/8 inches deep where the pinion came forward, what can I do if anything for that? I have thought about surfacing the flange but I would get rather thin. Second, what can you guys tell me about setting the pinion depth, I don’t see any way other than shims behind the front bearing?
Steve Lemberg
1936 Chevrolet 1 1/2 ton truck 1970 Mercedes 280SE 3.5 coupe 1987 Mercedes 560SEC supercharged 1989 Mercedes 300CE 5.0 M119
#44960 07/18/2002 5:11 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Steve , the 1/2 ton trucks had shims in front of the double row ball bearing . The 1 1/2 ton don't show any shims in the book , either in the parts or the assy . The pinion depth must work out pretty much ok , just fitting it up . Don't know what you can do about the worn nose , short of machining it and fitting a spacer to match. It's a bit hard to visualise , can you post a pic ? | | |
#44961 07/18/2002 5:38 AM | Joined: Nov 2001 Posts: 38 Member | | Member Joined: Nov 2001 Posts: 38 | Dusty,
I didn't see any shims either, that's why I ran it up the flag pole. My tomorrow your yesterday I will take some pictures of the rear end and post them. I don't know how many of the folks here would like photos of a 4-speed crash box and a big rear end but I could do a whole photo essay on both rebuilds. That transmission is so simple my mother could rebuild it. I hope to have the truck back on the road this week-end, my bearing guy said Friday for the double row pinion bearing. I sure hope this truck is quiet after all this, then I can put in a radio
Steve Lemberg
