1 members (1 invisible), 56 guests, and 6 robots.
Topics128,014
Posts1,055,324
Members48,419
#449037 09/04/2008 8:44 PM
I am looking for suggestions on where I can find a piece of trim that screws in on top of the dash that also goes the whole length of the window. It covers the crack between the window rubber and dash. I have looked through all my catalogs and havent seen it. I am fresh out of ideas on where to look-thanks
bolted 54 #449049 09/04/2008 9:21 PM
I think you are refering to the garnish molding. This in fact surrounds the whole window. I'm not entirely sure about the '54
but on mine (a '50) there are two trims joined at the middle of the dash and at the top of the windshield.
I don't know if you can buy them new but your best bet would be to try and find good second hand ones from one of the many sellers in the swap meet section.
I could actually be doing with a new set myself!
More pix on Flickr.
jockbolter50 #449057 09/04/2008 9:42 PM
I think he's talking about the trim covering the defrost vents in the dash...
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #449070 09/04/2008 10:15 PM
Is the defrost vent not a louvre cut into the Garnish trim? This fits above the defroster hose attachment that screws through the dash.
More pix on Flickr.
jockbolter50 #449091 09/04/2008 11:48 PM
I'm not sure about the pre-'54 AD's, but on my truck there's only one piece of trim.(along the bottom of the windshield)
It covers(only blocks the view of) the open slot along the windshield where the defroster air blows out.
David Colter
54TOW #449098 09/05/2008 12:14 AM
The 1954 defroster vents' cover (or window trim - not really a garnish molding but it has been called that) on a 54/55 truck is completely different from window trim used in earlier years, probably in keeping with the change from 2 flat windows to one curved window. The 1954 strip/molding is held down with about 5 screws into the dash and spring-like standoff clips (that are harder to find than the trim-strip/molding).
These parts are not sold in reproduction, so your best bet is to post a Want Ad in the Swap Meet forum.
Tim
tclederman #449101 09/05/2008 12:27 AM
thats kinda what I was thinking -thanks anyways-so you think i should save the clips?
bolted 54 #449119 09/05/2008 1:31 AM
Yes, save the clips or sell them in the Swap Meet.
tclederman #449239 09/05/2008 7:20 AM
Hey, You learn something new every day! I didn't realise the '54/55 trucks were so different! grin
Next time I'll ensure my brain is in gear before engaging my mouth! dang
Jock thumbs_up
More pix on Flickr.
jockbolter50 #449267 09/05/2008 1:17 PM
bolted54,
I sent you a PM
