| | | Forums66 Topics128,022 Posts1,055,378 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44906 11/04/2003 1:08 AM | Joined: Oct 2002 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 60 | think I will change the rearend pig/pumpkin in the 51 chevy 3/4 ton so I can run 15" tires insted of the 17" that it came with. There is a 66 chevy 20 series that is a 4 speed with 16.5 tires on it.What gear ratio would it be and what would the ratio in the 51 be if they are stock?
Is the ratio stamped on rearend? Or do I count teeth when I get them out?
Will this swap let the 216 run down the road at 55 or so with out the motor rpms to high?
thanks for any addvice. Bill
Bill 1951 3/4 ton 5 window pick up 1955 GMC 1/2 ton longbed automatic
#44907 11/04/2003 1:30 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I believe the original ratio for the 3/4 Ton will be 4.57 and the big gear will have 32 teeth. | | |
