0 members (),
125
10
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | I have a 74 nova that i got to take the front clip out of to put it in my 53, i found out that the transmisson that was in the car that was connected to a six cylinder will hook up to my 350 engine. what do i have to do to , change flywheel, starter . thanks for you information | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i bet if you use the flywheel and starter from the nova it will work if you are using the nova's bell housing. we'll wait and see what everyone else says. good luck, hr | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | I think to move forward on this transplant, it would be wise to determine if the "350ci" motor has a 2 piece rear seal or a one piece rear seal. Then you would know which flex plate would be required. Once you know the number of teeth on the flex plate, the starter choice would be simplified. Should go pretty smooth, Good luck. | | |
