1 members (1 invisible),
105
Mod | | | Forums66 Topics128,089 Posts1,056,440 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44893 03/21/2005 5:42 AM | Joined: Oct 2003 Posts: 5 Late 1953 6100 | | Late 1953 6100 Joined: Oct 2003 Posts: 5 | Any advice on how to sneak a camshaft past rusted into their bores lifters? This is my first engine tear down and the pistons(aluminum) and steel lifters are stuck! I can rotate/force the cam with a wrench on the flats.
I have ATF soaking the pistons and lifters from the oil pan side but I would like to get the cam out of the way.
Thanks Pete | | |
#44894 03/21/2005 4:04 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Upside down, beat them out w/long skinny screwdriver or punch. Brian | | |
#44895 03/21/2005 5:57 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I've had better success with PBBlaster or Kroil than ATF.
Can you get a pair of vise-grips on the lifters? You can get them to turn to break them free. Also, if you have a big enough torch heat the block, but not the lifter. The expansion might help.
Fred 52 3600 69 C-10
#44896 03/22/2005 3:22 AM | Joined: Feb 2004 Posts: 29,828 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,828 | Soak them with Kroil for a few days, then drive them out from the bottom with a long punch. If you manage to move the lifters up about 1/8" or so, the cam should slide out under them, then you'll have more room to manipulate the lifters. If it's that tight, both the cam and lifters will be junk. Be careful and don't crack the block while you're removing the lifters! Jerry
#44897 03/22/2005 4:58 AM | Joined: Oct 2003 Posts: 5 Late 1953 6100 | | Late 1953 6100 Joined: Oct 2003 Posts: 5 | used an old hammer handle as a drift anyone got a spare thrust plate for the cam?  | | |
