3 members (panic, 2-Ton, 1 invisible), 133 guests, and 3 robots.
Topics128,260
Posts1,058,343
Members48,485
#448821 09/04/2008 3:03 AM
Apprentice
Apprentice
Hey Guys
Today I pick up an 84 gmc crew cab long box (not much of a stovebolt) my question is I have a 69 gmc 1 ton, the 84 has a rebuilt 454 (in super cond) what are the chances this motor will fit and if so how much trouble to do so, the 84 is a four wheel drive with a four speed my 69 is also a four speed.. but two wheel drive plus less stuff under the hood..
You got to burn it! To earn it!
1969 GMC 930 1-Ton Flatbed
PUSHNTIN #448830 09/04/2008 3:18 AM
It'll fit just fine, GM offered the big block as an option for that year truck, although that one would have been a 396. You just need the correct motor mounts. Should bolt up the existing bellhousing and trans fine. Use the 454 flywheel, though, as the 454 is an external balance engine.
Bill Burmeister
LONGBOX55 #448832 09/04/2008 3:26 AM
Apprentice
Apprentice
Thanks Longbox55
That great info
