1 members (baldeagle),
89
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44861 10/24/2003 9:08 PM | Joined: Apr 2002 Posts: 11 Member | | Member Joined: Apr 2002 Posts: 11 | I have a 63k10 with a t-221 Rockwell t-case. It whines badly. I pulled it, and discovered that the bronze bushing on the front input shaft (from trans) was worn badly to the point that the constant mesh gear had slight "wobble" play and the front output shaft (to front rear) was seized onto the helical constant mesh gear.
I replaced all the bearings, turned a new bronze bearing for the input shaft and replaced the front output shaft from a spare case. I reset and shimmed the whole assy according to the book specs as far as end play, preload etc...
Now the bastard whines worse than ever.
Is this a situation like a ring and pinion where "matched, run in gears" can't be messed with or reset ever again in their lifetime? What are my options for this t-case? I know of no new parts available...
63 K10 Fleet 454
#44862 10/24/2003 9:17 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yep, once gears start whining, they never stop. Kinda like Chief.
#44863 10/24/2003 9:33 PM | Joined: Apr 2002 Posts: 11 Member | | Member Joined: Apr 2002 Posts: 11 | OK, I guess the next best thing is to cross my fingers, go back and rebuild the donor case... Thanks.
63 K10 Fleet 454
#44864 10/25/2003 12:31 AM | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | If you haven't already, you could try the NAPCO forum for further opinions. It is listed in the Links section. | | |
#44865 10/25/2003 1:44 AM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | | | |
#44866 11/08/2003 3:00 AM | Joined: Nov 2003 Posts: 13 Member | | Member Joined: Nov 2003 Posts: 13 | what parts do you need I have just rebuilt my t-221 and have parts left out of a donor case. | | |
