1 members (WingWright), 103 guests, and 1 robot.
Topics128,049
Posts1,055,680
#448575 09/03/2008 2:09 PM
OK this crap is driving me nuts. My rocker arms are hitting the intake side of the valve covers and I don't know why. The first time I had cheap stamped steel covers on and wrote it off as just that, cheap covers. Now high dollar billet covers and they still hit. I've pulled new rockers off the shelf at the parts store and they match. Mesured out perfect. The only other thing I can think of is the heads don't match the block. The block numbers come out to a '78 SBC 350 now the only numbers I can find on the heads are 333882. Can somebody ID these for me. I'm thinking they might be 400's or 305's or something thats throwing off the rockers.
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
Bluepen #448580 09/03/2008 2:27 PM
They make tall covers to eliminate that problem. You got them?
gazim #448581 09/03/2008 2:30 PM
The head you have is a 74-80 head that was common on a 350/400 engine. has 76cc chamber with 2.02/1.60 valves.
gazim #448594 09/03/2008 3:24 PM
Thanks gazim.
The rockers are not hitting the top of the covers they hit on the side towards the intake thats whats got me stumped
David
Just a firefighter,
'46 1/2 T Panel
Bluepen #448599 09/03/2008 3:36 PM
You got me David. You arn't trying to use the new cover with the bolts in the center of the covers are you??
gazim #448654 09/03/2008 6:19 PM
H Online: Content
If they're hitting the sides of the valve cover, the cover is on upside down. Turn them around and see how they fit!
Well I figured it out finally!!!! Even after I took one of the rockers off, took it to the parts house and checked it with calipers against a new stock rocker and it checked perfect. I got fed up and got a whole new set of rockers, pivots and nuts. And behold no more hitting and it even runs better. The only thing I can figure it is the PO had put locks on the studs and for some reason it effected the way the pivots moved or something because the locks were NOT hitting the top, only the rockers scraped the side of the covers toward the intake.
Either way it's fixed now, thanks
David
Just a firefighter,
'46 1/2 T Panel
Bluepen #449823 09/07/2008 2:57 AM
H Online: Content
I've encountered that problem with engines that have had the rocker arms replaced with 1.6:1 ratio rockers, rather than the stock 1.5:1 ratio ones. It's necessary to relocate the rocker studs about 1/16" further away from the valve stems, and do some pretty sophisticated modifications to pushrod length and rocker geometry to make the 1.6 rockers work right. On anything other than an all-out race engine, the performance gain is not worth the effort.
