5 members (Jon G, Gdads51, 3B, NJC, 1 invisible),
102
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,130 Posts1,056,367 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 16 New Guy | | New Guy Joined: Jan 2006 Posts: 16 | Hello all...Is there a conversion kit out there for a 60-63 with a 235? If not, anyone have any idea's on what would work and how would the bracket set up be with the straight 6? I'm assuming the brackets for the pulley's are different than on a V8. In the process of completing a frameoff and nows the time to make the change. Any help is much appreciated. Thanks!
fat60rat
FAT GIL
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | **bump**
can anyone help this guy out?
-W | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | There was a dealer-installed power steering kit available for the '55-56 model passenger cars, and maybe later ones as well. This kit provided a power cylinder that attached to the steering linkage and gave assist that way. If you can find a mid-fifties passenger car with that 'external' power cylinder, along with the pump, control valve and brackets, maybe that will help you. At best, that setup was only a moderately useable substitute for the integrated Saginaw power steering gear (the really good one), but it worked. I think the '58 passenger cars went to the itegrated gear. If you really want power steering, look for a '59-60 passenger car with the integrated steering gear and change the steering column and probably all the steering linkages- I think most of them are different between manual and power streering.
Maybe someone else can give better insight on your question, but I would be inclined to leave things as they are.
Harvester | | |
