| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 2 New Guy | | New Guy Joined: Aug 2008 Posts: 2 | 52 3100, the emergency break latch mechanism (flat bar with a hole around the pedal shaft connected to the release) doesn't grab the break pedal. Any experience, suggestions appreciated. | | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | It is probably deformed from its intended shape. Mine had slowly taken on a slight curve which wasn't angled enough to "catch" the rod when you apply the emergency brake pedal. All I had to do was remove the flat bar and bend it back on an angle so it could catch on the shaft again. Fred | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Skip's Truck,
I think that if you disassemble the mechanism, you can stick the little flat bar in a bench vise and sharpen the inner edge with a rat-tail file. This will give it new 'tooth' and allow it to grip the pedal shaft again.
Stuart | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Shouldn't there be a spring between the bar and the floor also? | | | | | Joined: Aug 2008 Posts: 2 New Guy | | New Guy Joined: Aug 2008 Posts: 2 | To all - good ideas for those of us not so mechanically inclined. Wear and tear is probably the culprit. Thank you. I'll check on the spring idea too, makes sense. This IS a great site.
Skip | | |
