0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#448034 09/02/2008 1:12 AM
52 3100, the emergency break latch mechanism (flat bar with a hole around the pedal shaft connected to the release) doesn't grab the break pedal. Any experience, suggestions appreciated.
It is probably deformed from its intended shape. Mine had slowly taken on a slight curve which wasn't angled enough to "catch" the rod when you apply the emergency brake pedal. All I had to do was remove the flat bar and bend it back on an angle so it could catch on the shaft again.
Fred
Skip's Truck,
I think that if you disassemble the mechanism, you can stick the little flat bar in a bench vise and sharpen the inner edge with a rat-tail file. This will give it new 'tooth' and allow it to grip the pedal shaft again.
Stuart
Shouldn't there be a spring between the bar and the floor also?
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
To all - good ideas for those of us not so mechanically inclined. Wear and tear is probably the culprit. Thank you. I'll check on the spring idea too, makes sense. This IS a great site.
Skip
