Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Gdads51, Otto Skorzeny, Cosmo, MickeyP), 72 guests, and 0 robots.
Topics128,007
Posts1,055,279
Members48,418
#447944 09/01/2008 8:13 PM
I have a 37 GMC, with a 250 from a 72 nova and a t5 from I don't know what mating these 2 things together is a bell housing from a 70 something Chevelle. Now for my question about flywheels are all the small block and newer 6 cylinders flywheels the same or what. I know about the differance in teeth and clutch size. I just need to know what flywheel to get
1938 Gmc 1/2 ton
TheShoer #447963 09/01/2008 9:37 PM
i have switched several flywheels from v8s to inline 250s and 292s with no problem. i am not very familar with the v8 ones, but i think there are 2 main sizes for the inline sixes. i always use the large size on my 250s and 292s. the one in my 63 was the original one off the 327. it was the same size/ same teeth. there is a change in the flywheel to crank bolts size in the early 70's. if your flywheel has the larger holes i think you can get bushings to use smaller bolts but it's easier to just get the flywheel you need. i also have always used the heavier duty clutch and pressure plate. i bet someone will come along that knows more than i do. good luck, hr
hoggyrubber #448177 09/02/2008 2:54 PM
Before you mix and match flywheels, you also should know if the engine is neutral balanced or externally balanced. I presume that the older engines were externally balanced at the flywheel.
Tim K #448351 09/02/2008 10:11 PM
Riding in the Passing Lane
All the flywheels interchange on 63 up 6 cyl & 85 on back v-8s. Do not use one from a 400 small block. The 292s had larger bolt holes after the first few years & sometimes were heavier but I dought if you will run into one of those. There are 2 diameters of flywheels & the large one often does not fit in the bellhousing for the small one. Make shure the parts match.
1972 Chevy c10 Cheyenne Super
