2 members (Otto Skorzeny, 1 invisible),
92
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44783 02/08/2002 4:58 AM | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | what parts would be worth saving off of a 216 engine?
also the 4 speed that is in this, is the first gear a granny? | | |
#44784 02/08/2002 5:08 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If it's the stock tranny, an SM420, it's got granny. Reverse is to the left and back. As for the engine, the cores from the starter, generator, carb and such are worth a few bucks. The engine, some haul to scrap, others throw it in the back yard to keep up their CI.
Fred 52 3600 69 C-10
#44785 02/08/2002 5:15 AM | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | and some of us keepem. fixem.and putem back in. How straight is the oil pan,im looking for a good straight one.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | |
#44786 02/08/2002 5:47 AM | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | how is the bolt parttern on this sm420 compared to the early seventies? is this as stout as the early 70's sm420's, and will it bolt up? (will it bolt up to an SBC or BBC?)
as for the oil pan I will have to look to see how straight it is. if it is ok I'll send it to you for shipping & handling. it will be a little while until I get that thing out of the truck though.
generator and carb have been removed, but the starter is still there. | | |
#44787 02/08/2002 7:24 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | In the mid-sixtys the SM465 was introduced. Reverse is to the right and back. If you want a granny box that will bolt to a 70's bell, find a 465. Already set up for an open driveline.
#44788 02/08/2002 4:00 PM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Bolt patterns are the same on both units and the SM-465 will have a switch for your B/U lights!
GM Truck, four speed standard transmissions. Built by Muncie. Installed in: 1947 - 1967 Chevrolet and GMC trucks up to 2 1/2 ton. Model: SM-420 - Bearing Retainer/Bell housing opening size - 4 11/16"
Gear Ratios 1 - 7.06
2 - 3.58
3 - 1.71
4 - Direct
R - 6.78
Oil Capacity 5 1/2 pints
Installed in: 1968 - 1991 Chevrolet and GMC trucks up to 2 1/2 ton. Model: SM-465 - Bearing Retainer/Bell housing opening size - 5 1/8"
Gear Ratios 1 - 6.55
2 - 3.58
3 - 1.57
4 - Direct
Length - 12"
*** GMC ***
#44789 02/08/2002 4:24 PM | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | thanks for the info guys. I actually have the sm465 in one my of k5's, but for some reason I thought the sm420 ran for a longer duration in the vehicles, like through the early seventies.
at any rate the sm465's are a dime a dozen so either way it doesn't make much difference. | | |
