| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 58 | Do you have to take the whole fender off to get the radio antenna off on a 59 Chevy? Was having a hard time getting up in the wheel well. (Next step is taking the wheel off to see if that helps)
Update: It was way easier to do with the wheel off. Last time I tried to get the antenna off, it was 15 degrees out and I was in the snow. Thanks
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no you don't hafta take the fender off, just get yer smallest friend and stuff'em up there  it isn't real handy, but with good light you should be able to get it, especially with the wheel off Bill | | |
