7 members (baldeagle, Southerntruck, Hanks custodian, Woodcmiami, J Lucas, Rusty Shackleford, TooMany2count), 79 guests, and 1 robot.
Topics128,133
Posts1,056,398
Members48,441
Can anyone tell me the proper bed height where the front of the bed bolts to the frame. Mine has a steel bracket welded to bed and this is not right???? Thanks for any replies!!
Nick Burton
Nick,
I can't tell you the specific height, but I can tell you an easy way to find out. Purchase, or go to a vendor's store and measure, the stock wood blocks that act as the spacer between the front bed cross sill and the frame. By memory they are approximately square and about the same width as the top of the frame rail in that area.
Steve
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
Nick,
The factory wood blocks are 2 7/16".
Tim
1952 Chevy Shortbed
Photos in Photobucket
We make the front of the bed the same height above the frame as the rear of the bed. Measure your rear sill bracket height and that should be the same as the combined height of your front cross sill and the wood block that supports it.
Mar-Ktech
