| | | Forums66 Topics128,108 Posts1,056,230 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 6 New Guy | | New Guy Joined: Aug 2008 Posts: 6 | Are these for a 216 motor or GMC ? Hello and Thank you Pic 1 Pic 2
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Chy, do they have any casting numbers on them? The four bolt mount is like the old GMC, but these two flywheels are for different styles of clutch, and I don't think I have ever seen a GMC with a "Long" style clutch, hope that helps. | | | | | Joined: Aug 2008 Posts: 6 New Guy | | New Guy Joined: Aug 2008 Posts: 6 | Hi and thank you here's the back They say Albro,I think the one is for Ford Clutch. Pic 1 Pic 2 Pic 3 Pic 4
| | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | I've got both a 1950 and 1955 truck flywheels out right now and cleaned up. Do you need pictures of them? The starter tooth count is different on them, of course. Fred
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Guys, there's a reason the image button was removed from the reply form. Read all about it by clicking the "Posting images in the Stovebolt Forums" button in the left column. | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Are these aluminum flywheels?
Hoyt | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | ALBRO flywheels are aluminum. They were first manufactured by Paul Schiefer of the more famous Schiefer brand shortly after WWII. Most likely they are Ford flahead versions as that was his and the California interest at that time. Later he did produce GM versions.
Drew
| | | | | Joined: Aug 2008 Posts: 6 New Guy | | New Guy Joined: Aug 2008 Posts: 6 | ALBRO flywheels are aluminum. They were first manufactured by Paul Schiefer of the more famous Schiefer brand shortly after WWII. Most likely they are Ford flahead versions as that was his and the California interest at that time. Later he did produce GM versions. Was told they are NOT Flathead cause of the larger center hole,and the 5th hole for lining up with the pin. It has 139 teeth Sorry about the picture post
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Here's a pic of a stock 1950 Chevrolet 3100 216 Flywheel to compare with your ALBRO Aluminum Flywheels. Hope it helps.
http://pic19.picturetrail.com:80/VOL1061/3611363/16876743/332453213.jpg
Drew
| | | | | Joined: Aug 2008 Posts: 6 New Guy | | New Guy Joined: Aug 2008 Posts: 6 | Bloody hell,,back to the drawing board .. Thanks | | |
