6 members (MickeyP, 32Fordpuchoptop, J Lucas, Gdads51, chevyb, Bill Hanlon), 185 guests, and 4 robots.
Topics128,093
Posts1,056,154
Members48,436
Chy
Offline
Are these for a 216 motor or GMC ? Hello and Thank you smile
Pic 1
Pic 2
3B Offline
Hy Chy, do they have any casting numbers on them? The four bolt mount is like the old GMC, but these two flywheels are for different styles of clutch, and I don't think I have ever seen a GMC with a "Long" style clutch, hope that helps.
Chy
Offline
Hi and thank you here's the back They say Albro,I think the one is for Ford Clutch.
Pic 1
Pic 2
Pic 3
Pic 4
I've got both a 1950 and 1955 truck flywheels out right now and cleaned up. Do you need pictures of them? The starter tooth count is different on them, of course.
Fred
Guys, there's a reason the image button was removed from the reply form. Read all about it by clicking the "Posting images in the Stovebolt Forums" button in the left column.
Are these aluminum flywheels?
Hoyt
ALBRO flywheels are aluminum. They were first manufactured by Paul Schiefer of the more famous Schiefer brand shortly after WWII. Most likely they are Ford flahead versions as that was his and the California interest at that time. Later he did produce GM versions.
Drew
Chy
Offline
Was told they are NOT Flathead cause of the larger center hole,and the 5th hole for lining up with the pin. It has 139 teeth
Sorry about the picture post
Here's a pic of a stock 1950 Chevrolet 3100 216 Flywheel to compare with your ALBRO Aluminum Flywheels. Hope it helps.
http://pic19.picturetrail.com:80/VOL1061/3611363/16876743/332453213.jpg
Drew
Chy
Offline
Bloody hell,,back to the drawing board .. Thanks
