3 members (Gdads51, Raymond HAYWOOD, IHPWR), 175 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#44699 11/21/2002 6:01 AM
I hooked up the vacuum line for my wipers to my double action fule pump and it sits there going "tweet,tweet,tweet" as the engine idles. I didn't bother to check the operation of the wipers since this really didn't sound right to me. I was wondering if anyone could tell me if this means the vacuum part of the pump is bad or does it need to be rebuilt or if it just needs some lubercation or what? Any info would be helpful.
Thanks! grin
#44700 11/21/2002 7:54 AM
could be a vaccuum leak the pump action is showing up.
#44701 11/22/2002 7:55 AM
Dusty,
Thanks for the reply...All new copper lines and hoses hooked up to it, I'm not felling any air moving around it when I put my hand down there. Just wondered if maybe there was a way to lube it up and see if that quiets it...maybe just squirt a little 3 in 1 oil, (or something like it), into the vacuum intake, kind of like I've heard some people do to the wiper moter to lube it. Suggestions?
#44702 11/22/2002 8:02 AM
54gmc, are you saying that you have the lines loose or not connected to the pump or not connected to the wiper motor and you hear the tweet,tweet noise with the engine running?
Did you hook up a vacuum guage to the vacuum assist on the pump and get a reading?
OR at least put your thumb/finger over the end of the line to see if you feel a vacuum?
I am just Curious smile
#44703 11/23/2002 2:24 AM
Mechainiac,
I hooked the vacuum lines back up and, lacking a vacuum gauge, just put my thumb over the end of the line and, sure enough, absolutely no vacuum. frown Guess it needs the vacuum part repaired. Is that possible and can anyone advise how to do it? :confused:
Thanks!
#44704 11/23/2002 6:56 PM
The pump has a diaphragm just for the vacuum end of the pump.(top end of the pump).It should be rebuildable /replaceable. I am not sure who offers a rebuild kit, You may have to get some reinforced material and make/cut a diaphragm or at least take it apart and inspect it. It COULD possibly have a stuck check-valve.
#44705 11/24/2002 7:29 AM
You can also buy a new pump. When I checked at my local parts store it was about $60.
Fred
52 3600
69 C-10
#44706 11/24/2002 7:47 PM
I need to make a correction as the vacuum pupm part is at the bottom of the fuel/vacuum pump!
