3 members (Dennys28, Oswald, Shade Baby), 110 guests, and 3 robots.
Topics128,125
Posts1,056,336
Members48,439
#446773 08/29/2008 5:00 AM
TRIED THE SEARCH BUT CAME UP EMPTY. HOW CAN YOU TELL THE DIFFERANCE BETWEEN A STRAIGHT 6 AND V8 BELL HOUSING??? SOME ARE SQUARE AT THE BOTTOM WHERE IT BOLTS TO THE CROSSMEMBER. OTHERS I HAVE SEEN HAVE A TAPERED END ON THEM.
FOR EVERY PURCHASE MADE BY A BOLTER I CONTRIBUTE BACK TO THE STOVEBOLT SITE.KEEP ME IN MIND FOR YOUR 47-59 ORIGINAL CHEVY TRUCK PARTS NEEDS. THANKS,JIMBO MY CELL NO. 817-648-3249 "SOME OLD CHEVY TRUCKS MUST DIE SO THAT OTHERS CAN LIVE"
In the history of Chevy truck bell housings, 1954 was a dividing year. 6 cyl. truck bell housings before 1954, had a flat or square bottom where the mount is located. 6 cyl truck bell housings starting in 54 and continuing through ? "not sure of the year" are angled where the mount is located. This also applies to the V8 truck bell housings. Because of this a V8 bell housing will fit a 54 chevy rear cross member.
The V8 passenger car bell housing has a different mount. They are attached with 2 bolts at the front of the housing, whereas the truck mount is attached with one bolt through the bottom.
Just to add to Lonnie's comments. The V-8 & 63 up 6 cyl bellhousing with the "angle" mount was used through 72.
There are no similarities between the V-8 bellhousing and the 235 where it mounts to the engine.
Fred
THANKS FOR THE HISTORY LESSON GUYS.I APPRECIATE IT.
