0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 34 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 34 | TRIED THE SEARCH BUT CAME UP EMPTY. HOW CAN YOU TELL THE DIFFERANCE BETWEEN A STRAIGHT 6 AND V8 BELL HOUSING??? SOME ARE SQUARE AT THE BOTTOM WHERE IT BOLTS TO THE CROSSMEMBER. OTHERS I HAVE SEEN HAVE A TAPERED END ON THEM.
FOR EVERY PURCHASE MADE BY A BOLTER I CONTRIBUTE BACK TO THE STOVEBOLT SITE.KEEP ME IN MIND FOR YOUR 47-59 ORIGINAL CHEVY TRUCK PARTS NEEDS. THANKS,JIMBO MY CELL NO. 817-648-3249 "SOME OLD CHEVY TRUCKS MUST DIE SO THAT OTHERS CAN LIVE"
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | In the history of Chevy truck bell housings, 1954 was a dividing year. 6 cyl. truck bell housings before 1954, had a flat or square bottom where the mount is located. 6 cyl truck bell housings starting in 54 and continuing through ? "not sure of the year" are angled where the mount is located. This also applies to the V8 truck bell housings. Because of this a V8 bell housing will fit a 54 chevy rear cross member.
The V8 passenger car bell housing has a different mount. They are attached with 2 bolts at the front of the housing, whereas the truck mount is attached with one bolt through the bottom. | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Just to add to Lonnie's comments. The V-8 & 63 up 6 cyl bellhousing with the "angle" mount was used through 72. There are no similarities between the V-8 bellhousing and the 235 where it mounts to the engine. Fred
| | | | | Joined: Jul 2006 Posts: 34 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 34 | THANKS FOR THE HISTORY LESSON GUYS.I APPRECIATE IT.
