| | | Forums66 Topics128,130 Posts1,056,370 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 19 New Guy | | New Guy Joined: Feb 2008 Posts: 19 | Can anyone tell me the proper bed height where the front of the bed bolts to the frame. Mine has a steel bracket welded to bed and this is not right???? Thanks for any replies!!
Nick Burton
| | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | Nick, I can't tell you the specific height, but I can tell you an easy way to find out. Purchase, or go to a vendor's store and measure, the stock wood blocks that act as the spacer between the front bed cross sill and the frame. By memory they are approximately square and about the same width as the top of the frame rail in that area. Steve | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Nick, The factory wood blocks are 2 7/16". Tim | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | We make the front of the bed the same height above the frame as the rear of the bed. Measure your rear sill bracket height and that should be the same as the combined height of your front cross sill and the wood block that supports it.
Mar-Ktech | | |
