7 members (eclector, 32Fordpuchoptop, Hotrod Lincoln, dt235sd, MickeyP, 2 invisible), 154 guests, and 1 robot.
Topics128,033
Posts1,055,531
Members48,425
#446473 08/28/2008 1:00 PM
V
V Offline
I rebuilt everything , put some new lines on, wont build up pressure,,,just pees out of the vent on the mc cap ???
Thanks irgil
virg912iowa #446495 08/28/2008 2:01 PM
sounds like your MC is air locked ...try bench bleeding it an then go from there?
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #446572 08/28/2008 5:34 PM
V
V Offline
You were probably partialy right. When I took it off one of the cups didn't look right. And I think I put it together wrong. Put it right and bench bled. I think that will do the trick. Will put the wheels back on and test it...Thanks...Virg
