2 members (DaveV, Napco Man), 99 guests, and 1 robot.
Topics128,260
Posts1,058,343
Members48,485
#446163 08/27/2008 1:39 PM
Riding in the Passing Lane
I have a 67 Chevy PU. The front end is from a newer model, and has disc brakes.
I haven't driven the truck much in the couple of years since I bought it.
The last time I drove it, after about 1/2 mile the right front brake locked completely up, and the back reservoir on the Master was very low.
Any ideas what this might be?
~ davey
1967 Chevrolet 1/2-Ton Pickup
I'm not sure if I was ever as good as I thought I was, but I know I'm not as good as I used to be.
I've forgotten more than I ever knew. Okay, where did I put it?
A man can never have enough tools
Lovett #446175 08/27/2008 2:58 PM
Sounds like it could be either a stuck caliper or a bad rubber line. I believe if you crack the bleeder on that side fluid should come out if it's a bad line (after pressure has been applied and that side is locked up). If no fluid comes out I would take a look a the caliper itself.
Neil
1955 Chevy 3200
Milhouse #446189 08/27/2008 3:41 PM
I had something similar,it was a stuck piston in the caliper
BC52 #446210 08/27/2008 4:42 PM
Thanks! I figured it's either the caliper or a line. Just curious.
~ davey
