0 members (),
140
0
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 51 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Sep 2006 Posts: 51 | I have a 67 Chevy PU. The front end is from a newer model, and has disc brakes.
I haven't driven the truck much in the couple of years since I bought it.
The last time I drove it, after about 1/2 mile the right front brake locked completely up, and the back reservoir on the Master was very low.
Any ideas what this might be?
~ davey 1967 Chevrolet 1/2-Ton PickupIn the Stovebolt GalleryI'm not sure if I was ever as good as I thought I was, but I know I'm not as good as I used to be.I've forgotten more than I ever knew. Okay, where did I put it? A man can never have enough tools
| | | | | Joined: Oct 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 99 | Sounds like it could be either a stuck caliper or a bad rubber line. I believe if you crack the bleeder on that side fluid should come out if it's a bad line (after pressure has been applied and that side is locked up). If no fluid comes out I would take a look a the caliper itself.
Neil 1955 Chevy 3200
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I had something similar,it was a stuck piston in the caliper | | | | | Joined: Sep 2006 Posts: 51 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Sep 2006 Posts: 51 | Thanks! I figured it's either the caliper or a line. Just curious.
