1 members (baldeagle), 79 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#44614 04/13/2002 5:48 PM
I read a lot about full pressure or full flow engines.
Can some one explain what these terms mean?
If an engine is not FP, what is it called?
What engines are FP and what are not? (Specifically 235's)
How can you tell a FP engine?
#44615 04/13/2002 6:02 PM
JD Bob, there was an EXCELLENT post here some weeks back regarding this very topic, and I thought I had it saved on my HD, but I can't find it! :mad:
Try the "search" feature, under where it says "post a reply", maybe you'll find it. grin
*** GMC ***
#44616 04/14/2002 3:47 AM
Full pressure means the crankhaft is drilled so the rod bearings get oiled from the main bearings.
The older Chev. engines used a dip system to oil the rod bearings.
Full flow means all the oil the oil pump is pumping is going through the oil filter.
kdot em3
#44617 04/17/2002 10:12 PM
A non full pressure is a dipper, babbit pounder, splashoil, low pressure, or non-insert (poured bearing) engine. Those are any 216 and the early low pressure 235. The later 235 was full pressure (insert bearings with drilled crank) but not full flow. Full flow means all the oil goes through the filter before it goes to the bearings. A bypass engine sends about 10% of the oil through the filter (if it exists) and back to the pan.
Paint & Body Shop moderator
