0 members (),
49
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44609 01/31/2005 5:05 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | This weekend I picked up a completely disassembled 235. One of the P.O.'s started a rebuild on it. All of the machine work is already done. The only problem is that none of the bearings (except cam) or rings were included. I need to know the original specs for cylinder bore and crankshaft journal sizes so I know what bearings, etc to buy. Does anybody have a source for these specs? TIA
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#44610 01/31/2005 5:24 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 235 specifications (from 1960 manual) General Bore 3 9/16" Stroke 3 15/16" Compression ratio 8.25:1 Horsepower 135 @ 4000 rpm. Compression (cranking) 130 psi (min.)
Torque, Lbs Cylinder head 95 Mains 105 Rods 40 Flywheel 60 Rocker arm 30 Bell housing 50
Rods & Mains Rod diameter 2.311" Mains ” #1 2.6835-2.6845" #2 2.7145-2.7144" #3 2.7455-2.7465" #4 2.7765-2.7775" Crank end play .003-.011" Rod side clearance .005-.012" Rear seal diameter 3.875"
HEAD Valve spring 65 lbs @ 1.844" + / - 10 lbs. Hydraulic lifter 1 1/2 turns. Solid lifters .006" in .016" exh. Intake guide height 1" Exhaust " " 15/16"
CAM Cam gear run out .004" max Crank gear " " .003" max Backlash .004"-.006" End play .001-.005"
Piston & Rings Piston clearance .0006-.001" Ring end gap .007"-.017" Oil ring rails gap .015-.055" Ring clearance in groove .002-.004" Ring clearance in groove .000-.008" (oil)
Flywheel Run out .008" max
See the USA in your vintage Chevrolet! My Blog | | |
#44611 01/31/2005 5:57 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | Just what I needed!!! Thanks a million, Dave!!
