| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | My speedometer cable broke, so I replaced it, housing cable and all. For about a week, the speedo worked fine, but has recently become erratic. At highway speed it will waffle plus or minus 10 mph. It settles down to zero when stopped. The cable is well lubed with lube which came with the cable. I pulled the cable and housing apart, and there are no tight bends or flaws in the assembly. With the speedo on the bench, the shaft into the speedo head turns freely and the worm gear which operates the odometer turns freely. I read the archives and learned about the spinning magnet which turns the needle. If I clean the head with WD 40 or brake cleaner, will that affect the spinning magnet's operation? Also, should the head be cleaned with compressed air? The spring which is visible looks too frail to stand up to an air jet. Thanks in advance for suggestions | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | That's word for word what I went through with my '54. Someone posted on here the vasoline trick; shoving some vasoline into the speedo cable opening and putting some on the end of the cable, then connecting it up. I used a toothpick to cram some into the speedo. All I can say, it worked like a miracle and I'm thankful for someone sharing their experience. Good luck.
