11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,347 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44586 04/06/2004 12:40 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Hi- I have a speedo and a gear reducer out of a 2 ton GMC truck. I was wondering if anyone knew where to get the rubber diaphram for the gear reducer. This is mounted to the back of the speedo drive and has a vaccum source to it. When you shift your 2 speed rear axle, it pulls a lever down with vaccum, changes the ratio to the speedo so the correct speed is showing. Any tips would be appreciated.
The diaphram is bad on the reducer, giving me a leak and does not show correct speed.
Brent | | |
#44587 04/06/2004 4:57 PM | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | Try Ohio Valley Microtech, on Bardsdtown Road in Louisville, KY. They used to be Ohio Valley Speedometer Supply, and changed the name when they started rebuilding automotive computers, etc. They repair just about any small electro-mechanical device, plus rebuilding speedo heads, gas gages, etc. I don't have a current email or phone number, but a web search should come up with something. Jerry
#44588 04/08/2004 4:36 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Thanks, I will give it a try
Brent | | |
