7 members (51sub, 41 chev, WICruiser, Oldpickupman, Gdads51, Charles in CA, 1 invisible),
92
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 2 New Guy | | New Guy Joined: Mar 2008 Posts: 2 | I was wondering if anyone knew how to tell if the transfer case is in neutral on these, will it just shake free like a tranny or... I bought one I have to tow bar home and there's no shift pattern indication on the stick for the transfer case. I've not had much experience with 4x4's so forgive me if this is a stupid question, but any help would much appreciated.
| | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | It doesn't matter if it is a standard or automatic, put the main transmission in gear/park and see if it will roll with the transfer case lever at each detent. It will only roll in neutral.
If it has lockout front hubs, those should be set to free as well before you tow it.
1949 "Heinz 57"
