7 members (wilbur53, stlcardinalsguy, Wally / Montana, King Kielbasa, joe apple, Hotrod Lincoln, Otto Skorzeny), 105 guests, and 1 robot.
Topics128,052
Posts1,055,727
#445140 08/24/2008 4:28 AM
Apprentice
Apprentice
This sounds silly, I know, but I bought a new rubber cowl vent gasket for my '51 COE. Now that the truck is painted, I went to put it in, but couldn't figure out which way was up. It has a groove on one side which SHOULD fit over the raised rib, but it seems too long to go that way, and too short to sit in the outside "well". WTF? This should be the easiest part of the whole thing!
BTW: Cab inner windlace? Make sure the channel isn't crimped anywhere around the door, or you'll strain a gonad trying to pull it through! dang
~Bruce
oc51 #445455 08/25/2008 6:38 AM
I think the groove goes on the up side for the edge of the vent lid to rest in, but I'm not sure since I have a sponge rubber one and I'm not familiar with the COE vent.
Paint & Body Shop moderator
Bruce I uploaded a few pics of mine installed, hope they can lead you in the right direction.
I used 3-M black weatherstrip cement to install it.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #445668 08/26/2008 12:46 AM
Apprentice
Apprentice
Thanks to both of you!
4ontheFloor, that makes sense. I'll try it that way and see if it looks right.
Tim, mine is a little different shape than your 52's (yours appears rounded, while mine is flat on one side and tapered on the other) but at least I can see where it needs to go in the 'well' and I should be able to figure it out.
BTW Tim, I looked at pics of your truck and read your blog. It's going to be a beauty! I'm working on my doors now and waiting for the new vent window units to arrive. I agree with you: it's a nerve-wracking job!
When will you update your blog, so I can see how the truck is coming along?
~Bruce
oc51 #445820 08/26/2008 1:36 PM
Bruce,
click on my photobucket there is a bunch of pics there.
Truck has been on the road a bit an took a 3rd in a class of 22 modified trucks in a pretty good sized car show.
Tim
1952 Chevy Shortbed
