| | | Forums66 Topics128,007 Posts1,055,278 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 33 New Guy | | New Guy Joined: Jul 2007 Posts: 33 | I was looking into getting a speedo for my 54; I have a saginaw trans with 3:42 rear gear ratio so I know the stock speedo wouldnt work. I was wondering where I could find one that would work correctly and have the appearance of the original. I might consider just swapping out all my gauges depending on the cost. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Can't you use the original if you swap the gear in the tranny?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Can't you use the original if you swap the gear in the tranny? Yes. | | | | | Joined: Jul 2007 Posts: 33 New Guy | | New Guy Joined: Jul 2007 Posts: 33 | I'm running 30.5 tall tires. What gear # of teeth would i need to change to? thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think you need to find a correct pair of "drive" and "driven" gears for the transmission. Good luck. Or, it costs about $100 to have an adapter made. I did this after changing to a 3.55 rear-end and changing to taller radial tires - it is now within 1/2% accurate at 60 mph. Speedometer Shop I ran 4 measured ten-mile segments on an interstate at 60 mph. Sent them the average of the four measurements. | | |
