Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (jay d, 2 invisible), 54 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#445712 08/26/2008 2:43 AM
j54
Offline
I was looking into getting a speedo for my 54; I have a saginaw trans with 3:42 rear gear ratio so I know the stock speedo wouldnt work. I was wondering where I could find one that would work correctly and have the appearance of the original. I might consider just swapping out all my gauges depending on the cost.
j54 #445727 08/26/2008 3:18 AM
Can't you use the original if you swap the gear in the tranny?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
jmoore #445729 08/26/2008 3:19 AM
Yes.
Cletis #445753 08/26/2008 4:02 AM
j54
Offline
I'm running 30.5 tall tires. What gear # of teeth would i need to change to? thanks
j54 #445762 08/26/2008 4:37 AM
I think you need to find a correct pair of "drive" and "driven" gears for the transmission. Good luck.
Or, it costs about $100 to have an adapter made. I did this after changing to a 3.55 rear-end and changing to taller radial tires - it is now within 1/2% accurate at 60 mph.
Speedometer Shop
I ran 4 measured ten-mile segments on an interstate at 60 mph. Sent them the average of the four measurements.
