| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44546 07/22/2003 3:15 AM | Joined: Jul 2003 Posts: 4 Junior Member | | Junior Member Joined: Jul 2003 Posts: 4 | if i were to remove my 235 for a v8 [small block or big block], what hardware would be necessary for the conversion, and how much should i look to spend on it? additionally, would my original synchromesh 4spd [in my '62 chevy half ton] be adaptable, or would the tranny have to go, as well? thanks! | | |
#44547 07/22/2003 1:12 PM | Joined: Jan 2003 Posts: 43 Junior Member | | Junior Member Joined: Jan 2003 Posts: 43 | Check out this site for parts required to install a SB in your truck. Their parts are not expensive, and they have been around for a long time. http://www.chassisengineeringinc.com/ | | |
#44548 07/22/2003 11:05 PM | Joined: Jul 2003 Posts: 4 Junior Member | | Junior Member Joined: Jul 2003 Posts: 4 | thanks...but it seems they only carry parts for up to '57. mine's a '62. maybe i was reading it wrong? | | |
#44549 07/22/2003 11:55 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | if it is a 62, look for a factory 62 with the v-8 in it and see if it has the donor parts you need. These trucks did come witha V-8 option
#44550 07/24/2003 7:18 AM | Joined: Jul 2003 Posts: 55 Member | | Member Joined: Jul 2003 Posts: 55 | jb--I swapped out my 327 for a 250 in my '68 1/2 ton about two months ago. I know you're going the opposite way, but should be just the reverse of what I did. I swapped out motor mount towers and that was it. I had to move the towers up one bolt hole(I think). A small block should fit with no problem. I don't know if I really had to swap out the towers, but the previous owner welded one of them to the motor mount, so I did anyway. I don't know about the tranny. Sorry. Hope this helps. John.
1968 Chevy C-10, 250 and 3 speed on floor, Hedman headers, Offy intake, Edelbrock 600cfm 4 barrel, HEI 1966 Chevy C-10, motor and tranny went into the '68. Waiting to be restored.
