| | | Forums66 Topics128,281 Posts1,058,484 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 52 New Guy | | New Guy Joined: Aug 2008 Posts: 52 | My 51 3800 has a typical 8 bolt pattern rear hub/axle cap. While I was scraping away years of funk from the rear hub, I noticed that there was bright green paint over black paint on the hub caps (both sides). I can't tell if it extended onto the hub. Is this a factory thing? Or does someone know why it might be there? Curious. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Are the "hub caps" you mention actually the flanges of the axles where they bolt to the hub? This is the bolt pattern that inside of and smaller than the bolt pattern of the wheel itself.
I see no reason for them to be green.
Grigg | | | | | Joined: Aug 2008 Posts: 52 New Guy | | New Guy Joined: Aug 2008 Posts: 52 | That's exactly what they are,...the flanges. I thought there were small caps over the flange, but more cleaning showed just the flanges. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The larger AD trucks, 1.5 and 2 ton most often do have only a small cap with about five 5/16" bolts covering the splined end of the axle flange. But the 3/4 and 1 ton AD trucks all have the bolt in axle flanges.
Grigg | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Could just be an inspectors marking. I've seen that on later trucks, thry'll hit it with a shot of paint of a specified color to verify that the shaft bolts were tightened by the installer.
Bill Burmeister | | |
