Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (TUTS 59, Peggy M, Gdads51, 68ironhead, tclederman, 2-Ton, wilbur53), 154 guests, and 7 robots.
Topics128,281
Posts1,058,476
Members48,490
#445358 08/24/2008 11:51 PM
My 51 3800 has a typical 8 bolt pattern rear hub/axle cap. While I was scraping away years of funk from the rear hub, I noticed that there was bright green paint over black paint on the hub caps (both sides). I can't tell if it extended onto the hub. Is this a factory thing? Or does someone know why it might be there? Curious.
Are the "hub caps" you mention actually the flanges of the axles where they bolt to the hub? This is the bolt pattern that inside of and smaller than the bolt pattern of the wheel itself.
I see no reason for them to be green.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #445411 08/25/2008 2:51 AM
That's exactly what they are,...the flanges. I thought there were small caps over the flange, but more cleaning showed just the flanges.
The larger AD trucks, 1.5 and 2 ton most often do have only a small cap with about five 5/16" bolts covering the splined end of the axle flange.
But the 3/4 and 1 ton AD trucks all have the bolt in axle flanges.
Grigg
---All pictures---
Grigg #445418 08/25/2008 3:21 AM
Could just be an inspectors marking. I've seen that on later trucks, thry'll hit it with a shot of paint of a specified color to verify that the shaft bolts were tightened by the installer.
Bill Burmeister
