4 members (Gray_Ghost, dt235sd, WICruiser, Hotrod Lincoln), 91 guests, and 2 robots.
Topics128,140
Posts1,056,771
Members48,454
Does anyone have a set of plans or pictures of a 57 3100 with side rials on the bed? You know, that would fit in the stake holes?
I would like to make one that is 2 or 3 rails high that staggers as it goes toward the rear of the truck.
I have not seen many examples.
Also does anyone know of any hardware that may exist to fasten the front stakes to the side stakes?
I saw a 49 3100 once that had a beautiful set on it. It had front rails that were attached to side rails and they had metal corned fastners that slid into each other allowing you to take it off in 3 pieces. left, right and front.
Any plans or pictures with details?
Does anyone have a set of plans or pictures of a 57 3100 with side rails on the bed? You know, that would fit in the stake holes?
I am still looking for something.
Found some on ebay by TRUCKMANPARTSINC called "CHEVROLET GMC TRUCK BED SIDE WOOD STAKE SET 1947-1959" for $350 and $75 shipped. http://cgi.ebay.com/ebaymotors/CHEV...torsQ5fCarQ5fTruckQ5fPartsQ5fAccessories A bit pricey but not bad looking. Could work up a plan from the pictures.
Also found some Corner Stake Rack Connector set that would work nice with a side stake set in the front corners instead of bolting them, here:
http://www.redtrailers.com/ShowItem.asp?id=383CB
