3 members (J Lucas, HandyAndy, TUTS 59), 39 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#444274 08/22/2008 12:32 AM
Can one of you decode this serial number from a 19?? COE.
F353 8 S1170D
Thanks, Ernie
I can help you with the first 4 digits F353. "F" = COE, "35"= 350 series 2 ton,"3" = 161"in. wheelbase. Your next set of numbers don't seem right 8 S1170D. F353 would usually be followed by "24", which would be the engine cubic inch, of the 350 series trucks. Then a four digit serial number. Example "F352 24 1170". Also "FF"= 1947-'51. "F"= 1952-'55 1st series.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky #444335 08/22/2008 2:05 AM
Thanks for your help. I have the plate in my hand, so i am pretty sure the numbers are correct. The truck appeared to originally have a dump bed.
I think it could be a 55-57 F353 cab over with the 8 designating a V8 which would put it at 139" wheelbase. Does it have a 6 or V8? If it is a V8, the engine number should be on the block right above the oil pan right in front of the dip stick.
1 Offline
where are the pic's?
This was a partial truck on my father-in-laws farm. It was mostly missing. The grill, hood, motor and tranny gone. Windows broke out, dash stripped. He wanted to know what year it was. I took off the doors and drivers a pillar.
A picture of the door would narrow it quickly...
OldSub #444682 08/22/2008 7:41 PM
Does the windshield pillar slant into the door jam where the hinge was or is there a dog leg in the windshield pillar. This would distinguish a 55 1st series and earlier from a 55 second series and later. I am still thinking the number 8 denotes a V8 which was not offered until the second series 55 through 59.
I have one of the doors in the back of my pickup, My guess is later '55 and up.
Thanks, Ernie
BTW, it had a big back window, makes me think it was a 55-2 or later.
Probably a 55-59 350 V8 cab over 139" wheel base.
If it's a '55-'59 It will actually be a LCF (Low Cab Forward) "F" model GMC, & not a COE. Check out this link, http://www.classiccoe.com/oldcoetrucks/5459.htm
Spanky Hardy
1950 GMC 250 1-Ton
