0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 5 New Guy | | New Guy Joined: Aug 2008 Posts: 5 | I am in the begining stages of restoring my 55 one ton. The toe boards are rusted pretty bad. Is it better to cut these out with a zip saw or a cutting torch? I am fairly new to body restoration so any advice would be greatly appreciated. Chuck
Schweikerts Last Stand
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | It is tempting to use a torch, but I went through that many years ago. Something always warps and a mess is created. A sawzall , angle grinder and die grinder do a much better job. I use a die grinder to find how far the rot goes and where I have good metal to weld to. | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I bought a nibbler but ended up using a 4" side grinder with a cutting wheel for most of my cutting. It's also handy to have snips, cold chisel, and other metal cutting tools handy to get into corners and inconvenient places.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
