0 members (),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44435 01/10/2003 5:00 AM | Joined: Oct 2002 Posts: 43 Junior Member | | Junior Member Joined: Oct 2002 Posts: 43 | Hi everyone. The last few days my 235 has been leaking a bit of antifreeze out of the back of the motor. How many frost plugs are back there and can i change them by just taking out the flywheel? Or do i have to take off the whole bellhousing? :mad: I should have put new ones in when i rebuilt the motor 2 years ago  Just worried about how much room i have between the plugs and then end bellhousing. | | |
#44436 01/10/2003 3:04 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Hey PJ,
First, make sure its coming from the rear of the block. Make sure that a leak at the front of the motor isn't running down the back, or the head gasket isn't leaking.
Barring that, its not good news. There may be one core plug at the back of the motor. If there is, I don't know how you'd get to it easily without pulling the motor. If one core plug is going, the others can't be too far behind.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#44437 01/10/2003 4:27 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | One freeze plug buried under the bell housing. Why did those danged engineers had to put it there? A can of stop leak might get you by for a while, but it's not permanent. Use either the Bars leak or the copper seal types, not the Prestone in a bottle, it will plug up your radiator.
Fred 52 3600 69 C-10
#44438 01/10/2003 7:07 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Since I have one apart right now, there is a freeze plug actually behind the bellhousing that you would have to take the bellhousing off to get to, and a square plug for the oil gallery that you can reach behind the flywheel.
Check to make sure that the block drain fitting isn't leaking, too.
