| | | Forums66 Topics128,264 Posts1,058,356 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | does anybody know where I can get eye bolts for the lever shocks on a 37 GMC. These are the eye bolts the shocks bolt to at the springs
1938 Gmc 1/2 ton
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | These are a hard part to find. I had to have mine made by a machine shop. I took the rusted/broken ones in for the pipe size and had them weld a bolt to the pipe. After the weld was added, the head of the bolt disappeared.
I know it is not restoration perfect, but it was the best I could do. | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | Ya thats what I thought, I'm not to worried about original. I have a friend who owns a machine shop guess i'll have to go see him, thanks
1938 Gmc 1/2 ton
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Are you looking for the small plates that go under the U bolt on the springs? How many do you need? I think that I have a few in the parts bin.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
