| | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 51 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Sep 2006 Posts: 51 | I have a 1967 Chevy SWB truck. Both doors really need to be replaced, along with the front right fender. Rocker panels are rusted through.
I saw an ad recently for a 1968 LWB GMC that had no motor, but the body is supposed to be in very good condition.
Are the body parts interchangeable between a 67 Chevy and a 68 GMC?
I think the guy was asking $1000 for the truck. I figure I can talk him down a bit. If the body IS in good condition I figure I can get at least $1500 worth of parts off it, if not more.
~ davey 1967 Chevrolet 1/2-Ton PickupIn the Stovebolt GalleryI'm not sure if I was ever as good as I thought I was, but I know I'm not as good as I used to be.I've forgotten more than I ever knew. Okay, where did I put it? A man can never have enough tools
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | In 1967 GM started producing the GMC and Chevrolet 1/2 ton pickup trucks on the same assembly lines to reduce cost. The light duty GMC trucks were built in the Chevrolet plants, while the medium and heavy duty trucks continued to be produced at GMC Plants. This was, in effect, the end of GMC as a separate small truck division and afterwards there were basically no differences between the two trucks except interior and exterior trim. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2006 Posts: 51 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Sep 2006 Posts: 51 | That's what I was hoping. I know my truck has a 68 Back body on it. The right front fender is also a 68. Don't know about the doors.
Basically, all I can assume about this truck is that the cab is a 67 due to the VIN on the doorpost.
The front end is not 67 front end, nor is the steering section, which has been a major problem as something wasn't installed correctly during the switch. Greg told me he can fix that.
It's a shame the 68 GMC I am referring to is not an SWB truck, as the entire bedbox really needs to be replaced. Lots of deep dents inside the box that probably can't easily be repaired.
Thanks Mr. Scott.
