7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible), 88 guests, and 1 robot.
Topics128,074
Posts1,055,910
Members48,429
#444181 08/21/2008 9:42 PM
have a 35 1 1\2 ton flatbed with 207 six runs good , good oil pressure. over heats about every 3 miles. the radiators clean. the block has no rust and the waterpump appears to be working . can anybody give me some advice on this. thanks in advance.
redrose #444235 08/21/2008 11:43 PM
Do you mean that you drive 3 miles; it heats up, then cools down; you drive 3 miles, then cools down; etc. etc? Or, do you drive 3 miles, it heats up and will not cool down?
Lonnie Gallaher #444267 08/22/2008 12:25 AM
Definitely sounds like you have a block in one of the cooling passages. Or maybe it's not really hot, and your temp gauge is out.
Time to rebuild...
Dave
GMCdp #444530 08/22/2008 1:36 PM
Is the thermostat good? If the radiator is original I would have it recored. Also take the water pump off and inspect the impeller. And flush the block at the same time.
1949 Chevy 6400
1931 Chevy Firetruck
31,32,33 #445453 08/25/2008 6:24 AM
Check the timing and valve lash too, both of those can cause overheating when they are wrong.
Paint & Body Shop moderator
