| | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 6 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 6 | have a 35 1 1\2 ton flatbed with 207 six runs good , good oil pressure. over heats about every 3 miles. the radiators clean. the block has no rust and the waterpump appears to be working . can anybody give me some advice on this. thanks in advance. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Do you mean that you drive 3 miles; it heats up, then cools down; you drive 3 miles, then cools down; etc. etc? Or, do you drive 3 miles, it heats up and will not cool down? | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Definitely sounds like you have a block in one of the cooling passages. Or maybe it's not really hot, and your temp gauge is out.
Time to rebuild...
Dave
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Is the thermostat good? If the radiator is original I would have it recored. Also take the water pump off and inspect the impeller. And flush the block at the same time. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Check the timing and valve lash too, both of those can cause overheating when they are wrong.
