Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (66flea, DavidBraley, J Lucas, 55shaker, Mike B), 169 guests, and 6 robots.
Topics128,283
Posts1,058,504
Members48,490
problems with inner fenders to firewall bracket on the 58.
The brackets that are on the firewall to bolt the inner fenders to.
Both my brackets are pointing the same way?
The right bracket takes the bolt from the outside and the left looks like the the bolt would have to be installed from the inside of the inner fender.
Is this right?
I am not sure if somebody had these off while doing body work to the cab.
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
yes that's correct placement
Ya..seems wrong..but it's right
Keith
Regards,
Lindsay
