0 members (),
80
Mod | | | Forums66 Topics128,062 Posts1,055,857 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44370 07/28/2004 6:33 PM | Joined: Sep 2003 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 65 | Hey Pork is back...This site kicks a$$. Anyway, I bought new rear mounts and my '58 manual says the should be torques to 50lbs or so. As I start wrenching they seem to start expanding/flatten as if their going to blow out. Is 50lbs really the torque. I'm using the original 3 1/4" bolts. Is their a certain distance that the bolt end should stick out of the bell housing. Also the front mounts I just tightened securely.
pork-
59 1/2 ton 235 fleetside
"you can drink a girl pretty, but you can't drink a girl skinny"
1959 Chevy Fleetside 3100 Series BBW
#44371 07/28/2004 7:01 PM | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Since you're compressing a rubber mount, there will be considerable expansion before it gets tight enough. Use a little blue LocTite on the bolt thread, and sock it down. It's almost impossible to over-tighten those big bolts, unless you manage to strip the thread in the bellhousing. 50 ft/lb definitely won't hurt anything, threads or mounts. Jerry
#44372 07/28/2004 10:28 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There should be a sleeve around the bolt that stops it at the correct distance. often they are missing. they come with a lock plate at the bolt head but I usualy use alock washer instead. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
