5 members (Gib70, 3B, MickeyP, Jon G, 1 invisible),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,648 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | I'm looking for a trailer to haul my trucks, future projects and Farmall Cub on. I have located a bumper pull trailer with a 16' long by slightly less than 8' wide deck, 6000# GVWR, electric brakes, and 4' loading ramps. Can I comfortably get my '70 LWB C10 or '72 K2500 on this trailer? I don't recall what I rented to get the C10 home, but it seems like it was shorter than 16'. Also, what is the approximate weight of a 67-72 C10 and K2500, and a '51 3100 SWB? Seems like 6000# rating should give me plenty of capacity. Does this sound the the right trailer for the job?
53 Dumpy
1951 Chevy 3100 "Ernestine" 1970 Chevrolet C10 "Ol' Blue" 1940 JD "long-hood" B 1959 Jeep FC-170 1960 IH B275 2013 Chevy Silverado 2023 GMC Denali 2500HD
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | GVWR means including the weight of the trailer. If the trailer weights 2000 you only have 4000 in load capacity. That '72 K2500 might weigh close to that. I think the trailer is probably on the small side, but adequate.
At 16 feet it would not haul something like the 6400 you used to have and at 6000 GVWR would not have the load capacity for it either.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I am not trailer expert but appears to me it would do ok.. I use to pull a race car around with a pipe trailer, no brakes, and made it ok........... 70 half-ton International click here I miss the good old days
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | That's you in the driver's seat?  COOL  | | | | | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | The spec sheet says that the trailer weighs 1650 lbs, so I should have 4350 lbs to work with.
Oldsub, I will not have any more "big-uns" to haul around. Too expensive and hard to find parts for.
Unfortuantely, I think that the K2500 is going to be sold to make room for the trailer, so the C10 or 3100 will be the heaviest load for a while (until the next one follows me home).
53 Dumpy
| | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | my dealings with trailers has me wanting at least a 18 footer. that extra 2 foot comes in handy about balancing the tongue weight on vehicles with odd weight points. also you having a trailer will make you a very popular person amoung your friends and nieghbors. no telling what they may need hauled. this spring i bought a 20 foot trailer to haul my 6400 and coe on. it has worked out well, but wouldnt need the 20 foot if the big trucks were gone.
http://www.flickr.com/photos/11977495@N06/sets/ 1952 COE 1952 3100 1953 3100 1950 6400 1951 Suburban
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I bought a 20 foot 102 wide tilt a few years ago. It has 3500 axles with brakes on both axles. I pulled trailers for many years with no brakes and pipe frames that I couldn't open the door of the car I was pulling, but now I am spoiled. I jack up the front of the trailer, either winch the car on or drive it on and then can open the door. I can position the load so my tongue weight is right, and the longer a trailer is, the easier it is to back. I recently hauled a 3/4 ton stake bed that weighed a little over 5000 and set my cruise at 75 and never felt uncomfortable. I bought this one from a dealer who needed to liquidate some inventory for health reasons for $1800. I would never buy a trailer less than 20' and less than 102" wide and nothing less than brakes on both axles. The tilt is nice, especially for winching on vehicles with 4 flat tires. Mine is an H&H build in Iowa and I would recommend one to anyone. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | My current flatbed trailer is an 18 footer. Its too big to get into some places and too small to haul some loads.
My conclusion is that I need a 20 footer and a 16 footer. And a longer three axle goose neck. With four trailers in the stable I'd be more likely to have the right one on hand.
In addition to the 18 footer I own a pickup bed trailer and am currently storing a friends 8 foot utility trailer. There really are times when any one of the three makes most sense, and I could not argue just one size is always going to be best.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2008 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 50 | my dealings with trailers has me wanting at least a 18 footer. that extra 2 foot comes in handy about balancing the tongue weight on vehicles with odd weight points. also you having a trailer will make you a very popular person amoung your friends and nieghbors. no telling what they may need hauled. this spring i bought a 20 foot trailer to haul my 6400 and coe on. it has worked out well, but wouldnt need the 20 foot if the big trucks were gone. Sometimes it makes you too popular.I dont mind loaning my trailer to a few select people that I trust.But it happens at least once every couple of months, someone ive not met before or dont know well will stop and ask if they can borrow my trailer.I dont mind to help anyone out but id never stop and ask to borrow something of that value from a stranger lol.It got to the point this summer I started leaving a car setting on it.Just to have an excuse. | | |
