0 members (),
146
Mod | | | Forums66 Topics128,290 Posts1,058,565 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | I was wondering weather it would work to convert to disc brakes on my 50 gmc 3/4 ton I would like to do it on all four wheels would it be worth it? | | | | | Joined: Mar 2003 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2003 Posts: 45 | It can be done and it will be well worth it.  | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | There are three ways of getting disc brakes on your 3/4 ton. This guy figured out a way to modify the existing hubs. It may be easier to swap the 3/4 ton straight axle for a halfton, then use one of the many disc conversion kits. The third way it to go IFS, which makes more sense if you're planning to do rear discs (which means a new rear axle). Personally, I would do front discs only, it will still give you much better braking and you won't have to re-invent the parking brake linkage. | | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | I'm interested in your brake drums if you do this conversion! | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | From an engineering standpoint, Dorsey's use of mild steel is not wise. There is not enough strength there to use with something you have to trust your life with.
Fred 52 3600 69 C-10
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Kook, Are the brake drums the same between 3/4 and 1-ton trucks and Chevys and GMCs? If so, I'm sure I'll have some spares soon. | | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | I wonce saw a disc brake kit for GM 14 bolt axles that used rear calipers off a caddlac eldorado so that you had parking brakes and it also used the parts of a chevy 3/4 ton 4x4 front end (it was on some off roading web site)
I would NOT want a 1/2 ton front end in my truck I have being thinking that I would only do the front as the rear brake drums are qite large and seam to have plenty of stoping surface it will probebly depend on how much mony I have wen it comes time to do the brakes | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Use mild steel for the mock-up and for the final set-up use T-1 steel.
